[5th Gen : 08+]: Cooling fan issue
Old Mar 14, 2016 | 03:04 PM
Keferrier's Avatar
Keferrier
Default Cooling fan issue
My cooling fan comes on if I have the a/c or defrost feature on but will not come on if the heat is off or set for vents or the floor. I have changed the 2 separate relays and a 60 amp fuse with no difference. There is a resistor that is in the top of the cooling fan shroud and that test for continuity. Can anyone give any suggestions as to what I can do next? The van is to nice to bypass this with a toggle. And I can't afford to take it in. Any help would be greatly appreciated. Thank you.
Old Mar 14, 2016 | 03:50 PM
The engine cooling fan? It is designed to come on when the AC compressor is running, but it won't come on other times unless the coolant/engine temp gets hot enough. Are you experiencing overheating issues?
Old Mar 14, 2016 | 07:16 PM
Keferrier's Avatar
Keferrier
No overheating as far as my temperature gauge shows. Once it warms up it always stays at half no matter how far I drive. But I do get a coolant leak from the spigot on the overflow jug if I let it run for about 20 minutes or more. But the gauge never goes past half if I'm driving or letting it idle.
Old Apr 21, 2016 | 08:30 PM
Moparpwr86's Avatar
Moparpwr86
Question
I'm having similar issue fans not turning on and relays are all good and fan will run if hard wire it so all is operational. I have power at relay and ground at both wires at fan and at the resistor in the fan shroud not sure what says to turn power to it... has anyone figured this out?
Old Apr 21, 2016 | 10:36 PM
Keferrier's Avatar
Keferrier
The issue with my fans after testing all the wires and fuses and relays I ended up changing my coolant temperature sensor. And it fixed my problem. The sensor seemed to be working as far as the gauge on the dash shows but it wasn't opening a signal to the high speed relay (ground).
Old May 2, 2016 | 08:29 AM
RedCaravan's Avatar
RedCaravan
Never mind you had the same problem I had. Just watch for leaks in the radiator. After overflowing the system a few times my radiator had a leak and had to replace it.
