[3rd Gen : 96-00]: 2000 dodge grand caravan fuel trouble
Old Apr 5, 2016 | 01:04 AM
joseyogui's Avatar
joseyogui
Default 2000 dodge grand caravan fuel trouble
Hi, i changed my caravans fuel pump but now the car runs but if the car has 1/4 tank of gas if the car is on flat terrain no problem but if the car is up hill or down hill the engine stars to run bad and if i press the gas pedal it detpnats at the admision and if the car has 1/2 the engines trys to work good.
The only dtc its P1495 a small leak detected i changed the purge selenoid of the canister.
Could somebody help me please.
Old Apr 7, 2016 | 07:33 PM
offgas's Avatar
offgas
Sounds like the fuel pump is not positioned to pull fuel from the bottom of thank. In other words, it runs out of fuel at 1/4 tank. Did the purge solenoid fix the p1495 problem?
