[5th Gen : 08+]: EVAP Purge Solenoid
Old Apr 9, 2016 | 09:50 AM
smelanson's Avatar
smelanson
Default EVAP Purge Solenoid
I am planning on replacing the purge solenoid on my Caravan as I am getting the Gascap error and check engine light most of the time. It sometimes goes away. I already replaced the gas cap and that did not help.
Here is my question, how do I safely remove the hoses from the old one, they have black ends and appear to have some sort of a blue clip on them?
Old Apr 9, 2016 | 03:13 PM
offgas's Avatar
offgas
Can't help you with the hose removal. Mine was a 2006. They just pulled off. The electrical connector had a red locking tab. I was able to fix my evap problem by shooting a short blast of air (low pressure - about 5PSI) a couple of times in each of the valve ports. Been code-free for about 6 months now.
Old Apr 10, 2016 | 09:19 AM
smelanson's Avatar
smelanson
Changed it, still have the message though, I was able to get it off using a flat screwdriver and some time
Old Apr 10, 2016 | 11:10 AM
offgas's Avatar
offgas
Did you clear the code with a code reader?
If you did, and it came back, you may have a small split in hose? Especially around the service port and the PCV valve. After that, if nothing found, under the car for a complete inspection. Good Luck.
Old Apr 11, 2016 | 06:21 PM
smelanson's Avatar
smelanson
I did clear the code, I will have to take a closer look at the hoses
