[4th Gen : 01-07]: Limp mode but no codes
Old Jun 13, 2016 | 11:31 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Originally Posted by Cougar41
TNtech - Don't know why but there's no model year given by the OP. If you go by the bracket on the opening forum page he's in the 4th gen 01-07 range. MikeBruce has an IPM not a TIPM.
Why the hell did I think he had a 2008...sonofa...
Old Jun 29, 2016 | 04:33 PM
mikebruce700000's Avatar
mikebruce700000
Originally Posted by mikebruce700000
Yes, it is above the TCM. I'm going to check for shorts there in the next day or two.
I haven't found any shorts. I checked the normal trouble spots and the ground under the starter. I checked around the front of the engine, up to the TCM connector. I removed the covering at spots that looked suspicious (two locations) but found nothing.
Is it likely that the transmission range sensor might be the culprit?
I just removed the range sensor connector to check for corrosion. When I put it back on, the boxes around the gear indicator came back.
* Update. I replaced the TRS and still no change.
