[4th Gen : 01-07]: Dodge grand caravan
Old Jul 23, 2016 | 02:28 PM
Biglos458's Avatar
Biglos458
Default Dodge grand caravan
Here are my codes,p0700,118,107,108,1478,1598,can someone help,I've already changed battery and alternator but still have codes???
Old Jul 24, 2016 | 03:36 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
http://www.obd -codes.com/p0107
http://www.obd-codes.com/p0108
http://www.obd-codes.com/p0118
http://www.obd-codes.com/p0700
P1478 Battery Temp Sens Volts Out of Limit
Does not indicate anything but that the battery is warmer than the computer thinks it should be. The battery sits on top of the sensor. It could just be a bad sensor. Hope you had the battery tested.
Old Jul 24, 2016 | 03:55 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb
Old Aug 14, 2016 | 01:39 PM
offgas's Avatar
offgas
Did you find a solution? I have a similar problem. Thanks
Old Aug 15, 2016 | 04:10 PM
Cougar41's Avatar
Cougar41
If you're still around we need basic info like the model year, which engine and transmission, any maintenance done just prior. Just shooting from the hip you may have lost the reference voltage to several sensors.
Old Nov 19, 2018 | 08:25 PM
Biglos458's Avatar
Biglos458
Default EMISSION issues
Had to change the solenoid pack trans doing good but now have emissions issues codes p0135 p0161 p0141 had sensors changed but they still pop up is there a fuse for the sensors???
