[3rd Gen : 96-00]: Throttle Pressure Cable Adjuster - 31TH transmission
Old Aug 27, 2016 | 01:38 PM
sagedm's Avatar
sagedm
Default Throttle Pressure Cable Adjuster - 31TH transmission
2000 Dodge Caravan 2.4 L with 3-speed automatic.
I'm trying to adjust the throttle pressure valve cable. I see the plastic adjuster on the transmission bracket, but it appears to have some kind of locking ring over it. I would appreciate instructions on how to release the lock and make this adjustment from someone who has done it before.
Thanks!
Old Aug 27, 2016 | 07:01 PM
offgas's Avatar
offgas
I haven't done this myself. My factory service manual says to "loosen swivel adjustment lock screw". That's all it says - other than to tighten it to 100 inch lbs. Hope an expert will chime in. Good luck.
