[4th Gen : 01-07]: P0509 05 caravan iac issue
Old Sep 22, 2016 | 03:51 AM
rodopseth's Avatar
rodopseth
Default P0509 05 caravan iac issue
P0509. IAC code. cut, spliced and ran new wires to IAC solenoid/motor. confirmed proper wire and pin locations. at the ECM (located @ front left corner behind , connector C2, Orange plug, second one from front, pins 28 & 38. Any help or ideas on this? From what i've looked up so far, its the ECM
Old Sep 22, 2016 | 10:53 AM
cv2003's Avatar
cv2003
You didn't give much information there, such as the diagnostics you did before cutting the wires. It would be a waste of everyone's time to suggest things you've already done.
Old Sep 30, 2016 | 12:57 AM
rodopseth's Avatar
rodopseth
I'm not suggesting anything. Just looking for advice. My meter i realized is nfg so i assumed the one wire was broken but alas the wire swap did nothing. Is there anything else in the system that may activate this code other than the iac solenoid?
Old Sep 30, 2016 | 01:00 AM
rodopseth's Avatar
rodopseth
