[1st Gen : 84-90]: High beam/Low beam, Turn Signal Switch Handle
Hi folks,
Months, ago, I noticed how the roadway lighting that the Caravan puts out is terrible, so I wanted to upgrade the headlight lighting, a little. I built a headlight harness; bought some Silverstar Ultra bulbs, 2 Relays, and 2 Fuse holders.
My daughter dropped the Caravan off Saturday afternoon. It was dark by the time I finished. I turned the headlight switch on. The front marker lights and rear taillights were on, but headlights did not come on. I tested the High beam/Low beam switch. High beams came on. I switched from High to Low many times. High beams worked everytime it was switched on, but, the Low beams would work sometimes, and, sometimes not when switched.
I'm thinking that the High beam/Low beam switch at the steering column could be worn out and needs to be replaced. That switch is controlled by the same handle that controls the turn signals. The turn signals work everytime the handle is switched.
Anyone have any advice on things I can check or do?
When my daughter picked up the caravan that night, I asked whether she was having issues switching from low to high beams. She said, for a while now, sometimes she wouldn't have low beams and would resort to driving with highs on.
I'll probably be changing the Dimmer Switch out the next time she brings it by.
