Door Panel Removal
Old Nov 13, 2005 | 09:45 PM
ridingsc's Avatar
ridingsc
Default Door Panel Removal
I'm attempting to remove my drivers side door panel on my 2002 Dodge Caravan SE. My drivers side power window has stopped working and I want to check & possibly eliminate any potential wiring problems (40amp fuse is okay & passenger side works fine). I've removed the screws, popped off the plastic anchors & disconnected the lock/window harnesses but am dealing with trying to remove the door handle. As far as the window goes, it has stopped working in the past, but for what ever reason has corrected itself but now its out again. I've read some posts here regarding wiring damage & bad regulator assembly, binding motor/cables and need to know if I fall into these categories. Any help would be greatly appreciated.
Chuck
