[5th Gen : 08+]: 2014 airbag replacement
Old Nov 14, 2016 | 02:41 PM
87gn70gs's Avatar
87gn70gs
Default 2014 airbag replacement
just replaced airbags, clockspring,seatbelts ect.. in a 2014 caravan. Was told that the air bags my redeploy if id hook up battery. They say that I have to take it to dealer before hooking up battery so they can reset module. Anyone know if this is true? Any help would be greatly appreciated. thanks
Old Nov 14, 2016 | 02:50 PM
Tizzy1's Avatar
Tizzy1
There is no reset. You cycle the ignition to the on position and then connect the negative cable. If you don't get a boom, you turn the key off for 15 sec and then back on. The airbag lamp should come on the then go off after a few seconds. If so, all is good.
Old Nov 16, 2016 | 09:40 AM
87gn70gs's Avatar
87gn70gs
Lol. Thanks for the info. The possible BOOM is what I would like to avoid.
