[2nd Gen : 91-95]: 1994 dodge caravan
need some advice my van was working great until the timing belt went we install a new belt and water pump she try to start but wont kick over. We also add new plugs, wires, and distributor cap and rotor but she will still not kick over.
also we test the fuel pump and that seams to be working we are getting spark
does anyone might know whats wrong i have the junk yard coming to get her in a few days also she has a 3.0 engine and i do not think she has a crankshaft to replace
Thanks Michael
Thanks Michael
Likely you have the timing 180* out, or the distributor is off a tooth or two.
With the motor at TDC, the rotor should be pointed at the protrusion on the intake plenum, if it is not, you have the distributor off.
Why are you worried about it if the JY is coming to get it?
