[4th Gen : 01-07]: No 4th Gear, bad Trans or TC
Old Dec 20, 2016 | 04:08 PM
TRU's Avatar
TRU
Originally Posted by master tech
Okay, here is what may have happen. The clutch pack is out of specs due to a broken snap ring and causing you not to have 4th gear. So if you drive the vehicle and shifts fine thru the first 3 gears and feels like you are in neutral when you shift to 4th gear. Then you most likely have a problem with the clutch pack. This means the transmission will need to come apart.
Was hoping I didn't have to drop the trans again. I guess I'll figure out which snap ring broke once I get inside the hub. You know of a site where I can get the update clutches and snap rings? I know they were updated over the years and I want to make sure I get the latest ones. Also where to get the most reliable torque converter.
Thanks for the help, really appreciate it.
