[3rd Gen : 96-00]: Squealing belt won't stop
Old Jan 28, 2017 | 05:09 PM
Needhelp97's Avatar
Needhelp97
Default Squealing belt won't stop
Ok so here's the question I have a 97 caravan 3.3 the belt started squealing about a week ago replaced the tensioner pulley idler pulley power steering and water pump and belt (yes it all needed done) van ran quiet for about a day then started squealing when you pressed the gas now it is continues what else could be wrong every thing is running fine and working properly but the stupid squeal has me worried
Old Jan 29, 2017 | 02:43 PM
offgas's Avatar
offgas
Since nobody else chimed in - i would unplug the alternator an go for test drive. Might bring in a trouble code that may or may not reset itself. Others might disagree.
Old Jan 29, 2017 | 06:22 PM
44dakota's Avatar
44dakota
you said you replaced the pwr steering pump?? if so, its probably the pulley slightly out of alignment with the other pulleys, this will cause belt squeal until the pulley is re aligned..
Old Feb 6, 2017 | 12:24 AM
Michael Wood's Avatar
Michael Wood
If everything else checks out try installing a new belt. I always use the Goodyear Gatorback belts and have never had one of them squeal..ever.
The changed the name of them and now are called Continental Elite. In my opinion they are the best belts out there. Got one on the Caravan and 2 on my Corvette.
