[1st Gen : 84-90]: 1990 caravan 3.0 4 speed
Old May 2, 2017 | 01:43 AM
henry james's Avatar
henry james
Default 1990 caravan 3.0 4 speed
I'm new to the fourm.
i have a 1990 caravan with a 3.0 4 speed it only has 6500 miles on it. i started to have the transmission got into limp mode and not wanting to go into only do 2nd gear sometimes it would try to shift then shift back. ove change the shift solenoid, input and output sensors i even changed the flues and new filter. now it will do 1st 2nd and 3rd but wont go to 4th orverdrive. it will shift out of 3rd but will only try. i also put on some new grounds. could it be the tcm or a bad transmission
any idea. thanks
Old May 4, 2017 | 07:11 AM
smokesxt's Avatar
smokesxt
Have you tried unhooking the battery for a while to reset the TCM?
