[4th Gen : 01-07]: 2003 Caravan SE Door Window falls out
Old Jun 27, 2017 | 05:02 PM
JohnInNC's Avatar
JohnInNC
Default 2003 Caravan SE Door Window falls out
Hi, everybody... first time poster, strictly a backyard mechanic.
We have a 2003 Caravan SE, and have had a problem with the drivers side door window falling out of the regulator. Works otherwise, no stoppages or jams. Does sound a little slow, this time around I'm going to make sure to lube the tracks.
Posts here (about motor and regulator failures) told me how to put it back together the first time, but it popped out again after about a month. Second time I pulled the clips out and squeezed them together to tighten them up, that kept things together for about three months.
Any suggestions on what would cause this? Is the regulator likely to be warped, or out of adjustment? I'm not aware of any past damage to the door, but can't rule it out.
Thanks!
John in NC
