[5th Gen : 08+]: Dodge caravan 2012--How to reset tmps?
Old Aug 8, 2017 | 09:20 PM
cachinarcr's Avatar
cachinarcr
Default Dodge caravan 2012--How to reset tmps?
Today, i found the light of tmps is flashing on, i check the four tire pressure ,it is right pressure. so how to reset tmps for dodge caravan 2012?
Old Aug 8, 2017 | 10:15 PM
primem's Avatar
primem
if the light is on solid...its just low pressure and you can top up. When the light is flashing, there is a system problem. you can't reset it without a tpm registering tool.
if one of the sensors is not displaying a pressure in the evic...it may need a sensor. have a shop try to register the sensor...if it does not respond...replace it.
