[2nd Gen : 91-95]: 1994 Voyager 3.8L issue
Old Aug 24, 2017 | 07:13 AM
smokesxt's Avatar
smokesxt
Default 1994 Voyager 3.8L issue
1994 Voyager 3.8L swapped.
On my way to work this morning the van started running very rough, CEL came on.
I pulled the codes and got a code 27 (Injector control circuit does not respond, problem in circuits 3/4), and the code 32 (for the EGR which it's had for a while).
Until today this drivetrain has been working phenomenally. I don't want to drive it home for fear of wrecking something, but I don't really have a choice.
Hopefully someone has an idea where to start/what would cause this/etc.
Thanks in advance guys.
Old Aug 24, 2017 | 12:05 PM
smokesxt's Avatar
smokesxt
Checked connections at the injectors and going to the ECM, everything is good there. I don't see and broken/bare wires either.
Old Aug 29, 2017 | 07:03 AM
smokesxt's Avatar
smokesxt
Did some simple testing of unplugging injectors to find the one that wasn't firing. Number 6 injector was "dead". Tested to ensure it had power and was getting proper pulses, it was. Replaced it, problem solved.
