[4th Gen : 01-07]: Weak spark
Old Aug 31, 2017 | 10:23 PM
Narf's Avatar
Narf
Default Weak spark
I have a 2003 Dodge Caravan with a 3.3 flex fuel in it. A few weeks ago I noticed a misfire but no check engine light came on.... well it has gotten a lot worse. I chased the problem down to a coil pack dead in cylinder 5 only. I change the coil pack.. two weeks later the same misfire comes back this time each coil tests good and so do all the wires to the plugs. I bought brand new plugs and wires anyhow installed those and well installing the plugs saw that I had very weak spark at the actual Gap. Can anyone point me in the right direction here?
Old Sep 3, 2017 | 04:23 PM
Cougar41's Avatar
Cougar41
Still broke? Verify you're getting 12vdc at the coil connector. If that's good consider another coil.
