[4th Gen : 01-07]: 2005 engine in 2002 caravan
Old Sep 28, 2017 | 05:43 PM
mugenk20a's Avatar
mugenk20a
Unhappy 2005 engine in 2002 caravan
I've completed the swap and I had to swap the wire harness under the intake manifold that goes to the fuel injectors and etc from the old engine onto the new one. If I used the 2005 harness it wouldn't attach because the plug is too big and on the wrong side of the engine. The van won't start and I don't know what to do. It has new spark plugs and the firing order is correct. I pulled one wire of and attached an old spark plug to it and it fires once and then quits firing. I've searched and can't find a solution. Oh both are 3.3 engines. Thanks.
Old Sep 28, 2017 | 07:38 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
You're going to have to use original injector wiring AND injectors from the 2002. As for the other sensors, I think the cam and crank have different connectors, but are wired the same.
Old Sep 28, 2017 | 08:51 PM
mugenk20a's Avatar
mugenk20a
cool, how do I know what to cut and spice to get the wires to match up? The cam and crank sensor are the same I checked them with the local parts store. Thanks.
