[3rd Gen : 96-00]: Using a power probe on a single wire
Old Oct 5, 2017 | 02:55 AM
mike L's Avatar
mike L
Default Using a power probe on a single wire
I saw a video where a tech used a power probe to test the single wire (cooling fan relay to the pcm). With the a/c on or engine hot the green light blinked.(pulsed) on the power probe. Can I use a test light or a multimeter to do the same thing?
Old Oct 5, 2017 | 08:01 AM
Give it a shot and see. What vehicle? What is the issue?
Old Oct 7, 2017 | 12:58 AM
mike L's Avatar
mike L
Default testing relay single wire from relay plug to ecm
1999 caravan cooling fans not coming on.Not sure if a test light or a multimter would damage the ECM. The only test I have left is the single wire to the ECM.
