[4th Gen : 01-07]: 05 Caravan 3.3L V6
So about two weeks ago I hear a whiny noise from the engine that increases on exceleration but stops after a few days. Several days later I notice the water was low and that there appeared to be a leak under the radiator. The radiator was replaced and the codes showed the BCM might be going bad. The next day water was again leaking and this time it appears to leak from the water pump gasket to the engine. Is the water pump a coincidence? Or could the BCM be causing multiple failures? Could the code be wrong? The van has about 148,000 miles and is a 05 caravan with a 3.3L.
Last edited by Flcat718; Oct 11, 2017 at 01:15 PM. Reason: Highlight the problem better
