[5th Gen : 08+]: 2000 3.3 Caravan No spark help!!
Old Nov 7, 2017 | 11:16 PM
ourgang's Avatar
ourgang
Default 2000 3.3 Caravan No spark help!!
Hi and thanks in advance for any help. I have a 2000 Caravan with a 3.3 with about 100,000 miles. The van stalled out while driving today and would not restart. When I checked it out I found that I had fuel but no spark to the plugs. I removed the plug to the coil and found that there was no cranking voltage to the coil. I do get the initial voltage for a second with the key on. I decided to swap out the crank sensor with a replacement made by standard. I still have the same issue. I am thinking either a wiring problem from the ecm to the coil pack or the ecm itself. Any ideas or info is much appreciated as this is my work van and it's costing me money. Thanks, John
