[5th Gen : 08+]: Recommendations for air filters
hi all,
i'm looking to replace the air and cabin filters in my 2015 r/t instead of through the dealer.
I have to admit, i've been overwhelmed with the different brands out there.
Is there a tried and true filter you all would recommend?
Thanks, guys,
Thanks, guys,
cabin filter get anywhere, a **** filter here won't damage anything...
pay the extra money and get the factory air filter. factory filter meet filtering standards....aftermarket junk could cause a dust out condtions. You just don't know what your buying in the aftermarket...you do with oem.
the caravan is speed density fuel metering so you don't have a maf sensor...crap airfilter kill the hot wire on the maf sensor
when i worked for nissan...which uses maf sensors....aftermarket filters...the filter would be clean...the maf screen after the filter would be black with dirt (the factory nissan filter would be dirty but the screen after the filter would be clean...go figure)...the maf would fail not long after the dirt build up causing fuel trim lean dtc. $400 to replace the maf.
dodge doesnt use maf very often but we do see the results of dust out conditions (from bad air filters) on the diesel turbos......ya get what you pay for.
