[5th Gen : 08+]: Buying a first Dodge
Old Dec 10, 2017 | 12:36 AM
Nikolay Danov's Avatar
Nikolay Danov
Default Buying a first Dodge
Hello guys, i’m about to buy a Caravan 2011’, but i don’t know much about them. i need it for work and it’s the best offer which i found.this one have already 120k miles , but is in really good shape and looks like new , had just one owner. i want to know any opinions for the most common problems or what should i look before buying it. thank you!
Old Dec 10, 2017 | 02:07 AM
fca tech's Avatar
fca tech
the most common problem since it should have a 3.6 1st gen engine is the front cylinder head causing mis-fires that should still be under warranty since fca extended it to 10 years or 150k miles the second known problem is the roller rocker arms come apart and cause loud tapping noise and usually will take out a cam shaft those are the only major problems we see with them at the dealer I work at
