[3rd Gen : 96-00]: 2000 dodge grand caravan weird electrical issues
Hello all!
I got a pretty weird one. Scares everyone I talk to, guy at the auto parts store said my car was possessed by a demon. Maybe someone on here can shed some light on this issue. 2000 Dodge Grand Caravan 3.3L Flex Fuel engine
So, for starters, this has been an ongoing issue for a long while now, but finally rendered the car un-startable. Below is a list of the symptoms in the order that they happened.
-bought the car off of craigslist ( I know, I know... But I was broke, couldn't afford anything else )
-accessory socket at the back worked, but front one didn't. Interior lights also won't turn on.
-ran fine for a while
-interior lights worked for a minute
-accessory socket on the front worked for a minute, then sparked when I plugged in an outlet adapter. Died. Never revived from here.
-found that the battery was drained after parking it momentarily. Had to get a jump, but worked fine afterwards.
-interior lights died again
-Transmission had trouble shifting. Not slipping, but wouldn't shift when I put it into gear unless I floored it, then it shifted suddenly. (As if to send more power through the alternator???)
-meters on the dash would intermittently die and come back to life while driving. dash lights would be as bright as the cars RPMs. Power issues?
-got a new battery, didn't fix anything, same issues.
-on the highway, the cars meters all died suddenly and the car had trouble staying moving. Flooring it got me about 40mph maximum, and it was a struggle to keep it alive on the way home
-made it home, checked the wiring to the battery, everything is tight and fine.
-still started, but wouldn't get to speed.
-I had me a little ODBII-port light deal (https://www.autozone.com/gauges-and-...lay/571760_0_0) and when I drove it around for a bit and struggled to keep it up to speed, I took it home, and unplugging this device from the ODBII port killed it instantly.
-could start with a jump, but didn't stay on any longer than I had my foot on the gas.
-checked all the fuses, fine.
-relays would rapidly click when I tried to start it
-swapped each of the relays with a new one from the auto parts store, none of them worked
-found that there was an aftermarket alarm system installed. Ripped it out, spliced back together the starter wire.
-car won't start, no crank, rapid clicking on relay #13 under the dash, left side now.
-Replaced that, same deal, still clicked.
-short to ground? Voltmeter found that there resistance between the positive and negative connections when the battery was out! The hunt was on to find the short!
-traced every wire under the hood, save for the bundle that goes under the intake manifold. There was no thick positive cable going there, so I didn't check it. No short was found. Isolated the short to the fuse box itself.
-tore apart the fusebox looking for a charred insect or something.
-perfectly fine. But... wait... at the top of the fuse box, there's a positive and negative connection bolted to the same piece of metal?? Is that normal???
-put it back together, still won't start. No crank, no nothing.
I'm at my wits end here. I feel it wise to consult the experts on the internet before net neutrality gets shot. I have a list of things to check still (starter wire power when I try to start, and the starter itself, and the cables that go from under the hood to the interior instrument panel) but I was wondering if anyone on here had heard of similar things happening? Maybe you could point me in the right direction? Would the transmission shifting problem happen with a short to ground problem, or is it the transmission itself? Has anyone heard of a PCM or TCM failing and causing similar issues?
But I need to know, is it normal to have the positive and negative battery terminal connected to the same piece of metal on the top of the fuse box? Isn't that a horribly catastrophic short to ground on the fusebox? If that is the case, can anyone explain why one would do that? I'm at a complete loss here
Thank you so much for reading my long post. I just don't know where to go at this point, as I cannot afford a mechanic, and all the ones I talked to are scared of this thing.
I’m having the same trouble with my transmission, also my relay under the dash I’ve swapped around still hear the ticking. When I pull the speaker relay it stops. So my ex had some subs wired in and all that fun stuff but not from a professional. Now I’m trying to find a short in mine. Had to pull the memory fuse and re insert a new one for it to stop just don’t touch the stereo power button. I’m at my wits end as well and thinking of just selling it!
Hello all!
So I guess I'm asking if you figured it out.
