[5th Gen : 08+]: 2010 Grand Caravan 4.0L MAP sensor
Old Dec 20, 2017 | 12:18 PM
pierreshiny's Avatar
pierreshiny
Default 2010 Grand Caravan 4.0L MAP sensor
Hello,
Need help for a few questions:
1. I disconnected the
MAP sensor MAP sensor
, and the car can still start. Is this normal?
2. Is there a convenient way to tell if the MAP sensor is not working properly? I tried to use a multimeter to measure the voltages, but couldn't touch the electrode because the space is two narrow.
3. The MAP sensor installed on my car is 05033310AC. I found there's no screw on it to fix it on the
engine engine
. So if I need to replace it, how to get it out? Just pull it?
Thank you!
