[3rd Gen : 96-00]: Brake Line Replacement
Old Jan 29, 2018 | 07:23 AM
Arsenul's Avatar
Arsenul
Default Brake Line Replacement
So we got the van's serpentine belt on and it works it seems. There are still problems with it which I hope to get fixed soon. One I think is the brake lines. I think this because near the tire I saw liquid leaking. My mom drove it to her place today and also mentioned the brakes were stiff as well. I do plan on flushing the brake fluid and someday replacing them, but I feel like the brake line needs replacing. Does it take much to do that? What are your thoughts and suggestions on the matter?
Old Jan 29, 2018 | 07:55 AM
Depends on which lines you are replacing. Some require removal of other parts to get to, some dont. I would figure out which one is leaking and fix/replace that one first. Driving around with leaking brake lines is a recipe for disaster.
Old Jan 29, 2018 | 08:01 AM
Arsenul's Avatar
Arsenul
Yea the drivers side front one is where I saw the leak. I see it's hard to work with but better in the long run so might go stainless steel.
