Trans rebuild fail
Hello everyone. I recently attempted my first transmission RnR. Got the kit and went through it methodicallt replacing Clutches and seals step by step with the factory service manual. Put it back in and it will not move AT ALL. Now, I'm not a transmission guy, but I have 15 years in the industry as an ASE Cert. Mechanic (brakes, suspensions, exh., front end, alignment, engine, etc) and my associates refer to me as " Mr. Fix-It " because, well, I can usually fix about anything so I'm not without an above average understanding of how things work. Anyway, thought maybe it was because I needed to do the quick learn procedure but reading other threads I'm Thinking it' something else. If anyone has had , or knows of similar problems I would sure appreciate some sdvice, the owner would like his van back. Thanx.
Other than going back and checking/rechecking your work, not much else to offer from me. I leave that stuff to the professionals.
Originally Posted by jkeaton
(Post 3386523)
If you force 'limp mode' you should see 'R' and second gear only in 'D'.
You could either remove the eatx relay or disconnect the connector going to the solenoid pack on front of trans. Have you confirmed the shifter cable is moving the shaft on the trans? When you disassembled the trans did you find any damaged parts? Or any shrapnel? Did you check the planetary gears? Do you hear any noises coming from the trans when you try 'R', 'D', '3' or 'L' ?? |
When you installed the underdrive piston did you use the sleeve? Did the piston go in square? Did the reverse piston seal get put in? (many people forget this one)
Originally Posted by brianf989
(Post 3386529)
thank you. Hope it is something simple.
Originally Posted by as400pgmrs
(Post 3386881)
You could either remove the eatx relay or disconnect the connector going to the solenoid pack on front of trans. Have you confirmed the shifter cable is moving the shaft on the trans? When you disassembled the trans did you find any damaged parts? Or any shrapnel? Did you check the planetary gears? Do you hear any noises coming from the trans when you try 'R', 'D', '3' or 'L' ?? planetary gears visibly ok, play within tolerance. no noise from trans when shifted into gear, rpms lower like it' engaging but van just doesn't move. |
Originally Posted by FCA Master
(Post 3387529)
