[5th Gen : 08+]: 08 Grand Caravan Power Window
Old Apr 8, 2018 | 05:48 PM
syc06669's Avatar
syc06669
Default 08 Grand Caravan Power Window
So yesterday morning my windows worked fine, then in the afternoon i went to get coffee and the button for my window just buzzed when i tried to put it down, the passenger window goes down slowly but needs help to go back up. i took apart the switch and cleaned every connection and no change. I'm trying to find a wiring diagram so i can bypass the switch to see if its the motor or the switch before i start throwing money at it. I'm pretty good at fixing my own stuff I just can't find a diagram that doesn't require me to buy it or pay for a subscription.
Any help would be greatly appreciated, and if this question has already been solved I couldn't find it so sorry for a double post.
Old Apr 8, 2018 | 07:18 PM
georgef's Avatar
georgef
You can find free wiring diagrams here: http://www.bbbind.com/tech_database.html
Old Apr 22, 2018 | 12:13 PM
syc06669's Avatar
syc06669
OK, found where the problem is but now I'm at a stand still. with the door open everything works but closed it cuts out everything in the drivers door. if i open the door and move the harness going from the door into the van it all cuts out again. my thought is a connection at that point but am unsure how to remove the rubber cover to get at the wires and possible connection.
