[5th Gen : 08+]: 2014 Caravan Rotational Noise When Decelerating or Braking
Old May 21, 2018 | 01:29 PM
Tripster's Avatar
Tripster
Default 2014 Caravan Rotational Noise When Decelerating or Braking
Hello
strange rotational noise from front driver's side at any speed while coasting or braking. Front brakes and suspension are good. Jacked up front and in neutral spinning the Tire does not make any sound. But there is a strange sound when rotating the tires slightly back and forth. Sounds like it's coming from the transmission.
Trying to convert a video to upload.
Old Jul 19, 2025 | 07:33 PM
Carhvac's Avatar
Carhvac
Default Did you figure what is was ?
Hi did you figure it out I'm having same problem for 2015 caravan
