[5th Gen : 08+]: 62te transmission
Old May 31, 2018 | 02:05 AM
hswanier0513's Avatar
hswanier0513
Default Transmission in limp mode
Transmission completely rebuilt, ecm/pcm module replaced.. Unit works correctly while cold,after warm up unit stops shifting stays in 2 gear. Relays replaced. What is wrong?
Old May 31, 2018 | 02:31 AM
hswanier0513
Default 62te transmission
2010 3.8L 62te transmission completely rebuilt, and ecm/pcm replaced with oem parts. While van cold shifts correctly, when warms up goes into limp mode. This is what it was doing before it was rebuilt, also replaced relay pack. What have they missed?
Old May 31, 2018 | 02:39 AM
hswanier0513
Fluid was changed with rebuild. I had transmission rebuilt because shop said was necessary, changed relay pack. With all this new should not have same problem. Mechanic traced wires through harness. Could totally integrated power module be the culprit?
Old May 31, 2018 | 02:44 AM
hswanier0513
I have not received an answer. Are these generic answers what I am to expect?
Old May 31, 2018 | 02:47 AM
hswanier0513
Is there somewhere else I can go for help on line?
Old May 31, 2018 | 07:27 AM
Take it back to the shop that rebuilt it and explain the situation to them.
