[4th Gen : 01-07]: Power steering pump fuse?
Old Jul 7, 2018 | 10:14 PM
vespers_'s Avatar
vespers_
Default Power steering pump fuse?
I damaged the power steering cooler on my 2007 caravan 3.3 and the replacement will not come in before the van needs to be moved. Is there a fuse that can disconnect the pump so i can drive it without burning out the pump?
I looked at a fuse map but couldn't see a way. If not, is my option to just insert a tube in a loop so the fluid recirculates? Towing is not an option as the vehicle is located in a remote bush camp.
Thanks!
Old Jul 7, 2018 | 10:41 PM
primem's Avatar
primem
no fuse
bypassing the cooler is an option.
how far do you have to move this?
Old Jul 7, 2018 | 11:52 PM
vespers_'s Avatar
vespers_
About an hour and half drive on the highway unfortunately. I was under the impression it would be ok as long as it isn't too hot out?
Old Jul 10, 2018 | 12:09 AM
primem's Avatar
primem
temp wise you'll be fine...containing the pressure will be the issue. what kind of fittings?...formed tubes that are retained with clips?
