[4th Gen : 01-07]: Starting issue can only jump start from fuse box
Old Aug 20, 2018 | 07:45 AM
JRR's Avatar
JRR
Default Starting issue can only jump start from fuse box
Hi all - need help. 2002 Caravan EC 4 cylinder engine 265,000 (still does not burn oil!). I cannot start the engine from the key. I can jump the starter and I can remove the starter relay and jump the starter from the fuse box with the key on. I replaced with new: a starter relay and the ignition switch. Key cylinder is good as well. I have continuity from the fuse box to the (yellow wire) to the starter. I removed the starter relay and installed 2 jumper wires with a start button so I can use it for now. This has to be electrical. I had this issue 2 weeks ago and then it was working for another 2 weeks and now I can only start with jumping the fuse box. Any suggestions? Thank you JR
