2005 Grand Caravan Struts and Sway Bars
Subscribe
Aug 23, 2018 | 10:13 PM
Just a quick question,
I am replacing my struts (Monroe quick struts) and also the Stabilizer bar link (Moog Suspension Stabilizer Bar's) all parts are correct I only have one side jacked up and I am having a very hard time getting the stabilizer bar to fit.
Do both wheels have to be off the ground for the bar to fit?
Thanks
Reply 0
Aug 23, 2018 | 11:12 PM
when one side is lifted if puts the sway bar under tension. jack up both side equally. do both sway bars at the same time if you are doing 2...then the bar will pivot anywhere you want.
If you are only doing one side...put a large prybar between the bar and frame and pry down the bar until you get the link connected.
Reply 0
Subscribe
