[5th Gen : 08+]: 2014 which ATF to use?
Old Oct 30, 2018 | 05:24 PM
Jason Jia's Avatar
Jason Jia
Default 2014 which ATF to use?
Hello all,
I will be changing the ATF (drain and fill type of deal, not a flush), and I was wondering what fluid should I/can I go with? I have a Honda, and I know that they're pretty picky about using the dealer fluids, is it the same with the Caravan? Can I use the stuff I find at Canadian Tire, made specifically for Dodge vehicles etc.?
Thanks!
Old Oct 30, 2018 | 08:30 PM
georgef's Avatar
georgef
You can use any brand you want as long as it is licensed ATF+4 fluid, there is is listed of licensed brands here: https://www.centerforqa.com/chrysler-brands/
Canadian Tire sells the Motomaster ATF+4 https://www.canadiantire.ca/en/pdp/m...1527p.html#srp which is a licensed brand.
Old Oct 30, 2018 | 10:46 PM
primem's Avatar
primem
the best choice is the fca fluid. It has the proper friction co-efficient the trans is designed for. after market fluid made for multiple builds won't hurt it either but i'm particular so I put oem trans fluid in all my vehicles
