[General]: 3.6L Oil leak
Old Nov 26, 2018 | 11:17 PM
mrachedi2002's Avatar
mrachedi2002
Thumbs down 3.6L Oil leak
Oil Leaking, drip drip drip: new part as of 2014! Failure on Grand Caravan 2016 SXT 3.6L V^ 24V VVTm 6-speed automatic. Other forums also have like problem with 3.6L for Town and Country, Durango, and Jeep Cherokee and other Grand Caravans. Oil filter adapter is molded plastic part that sits on the top of the engine under the intake manifold with contains the oil filter adaptor and the metal oil cooler. Reported leak failure to Dodge Troy Michigan assigned reference 57490136. If you have problem call them 800-423-6343 and report your like problem w/reference number and maybe Dodge will understand that there is a design problem and issue a recall fix. Oil filter adapter priced a dealer $262.00+ Moparoverstocked.com has part for $182! Dealer repair cost for 3 hour job was over $800 that had mechanic hourly wage set at $100. Since not covered by recall or warranty took to local mechanic and saved a ton of money.
