cruse control fuse
Old Dec 10, 2005 | 07:18 PM
milburn207's Avatar
milburn207
Default cruse control fuse
where in the heck is the cruse control fuse or relay for a 97 dodge grand caravan?
the cruse control does not light up or work. when you first start the car the light gos on then off.
Old Dec 15, 2005 | 10:50 PM
greaseangel's Avatar
greaseangel
Default RE: cruse control fuse
Pop the hood and look to the right of your battery. There's a box there, take the lid off. On the underside of the lid, you will find a diagram of where each fuse is. I can't remember is the CC fuse is in there, but if it's not, look under the dash on the driver side.
Another question though, does your horn work? Is the airbag light on? If the horn and airbag are also malfunctioning, you've got a tougher problem than the fuse.
Old Dec 18, 2005 | 04:00 AM
brandoncrone's Avatar
brandoncrone
Its probably the clockspring (connects the steering wheel controls and airbag to the rest of the vehicle) There is a recall for this concern, no charge repair. There is no cc fuse, the cruise actuator is controlled by the engine control module.
Old Dec 20, 2005 | 01:55 AM
greaseangel
There's a recall for the clockspring? Even as old as our vans are it can get fixed?
I did not know there is no fuse, I just knew that if there was a fuse, where it would be
Old Dec 20, 2005 | 10:06 AM
brandoncrone
It sure can be fixed! Just call your dealer and tell them that your airbag light is on or your cruise does not work and they wil replace the clockspring free of charge.
Old Dec 22, 2005 | 01:19 AM
greaseangel
Wow! Thank you! I will call them whenever my van gets back from the mechanic. I told a friend who works in the service department about the problem several months ago, and he told me about the faulty clockspring, but he didn't say anything about a recall. Boy am I gonna chew him out lol!
