[5th Gen : 08+]: Turn signal light fuse
Old Apr 10, 2019 | 12:02 PM
ADAM1985's Avatar
ADAM1985
Default Turn signal fuse
Hey i have a 2010 dodge grand caravan, front turn signal light work on and somtimes works fast , i have the diagram for the fuses but i cant see any one says trun right signal light. Can you tell me witch number please ,
Hi i have 2010 dodge grand caravan, im looking for the fuses number of front light head and signal turn, i checked the manual but there is no words says lighthead or signal turn , can any one tell me please in under witch number or description i can locate it , thanks
Last edited by jkeaton; Apr 12, 2019 at 11:57 AM. Reason: Already started a thread.
Old Apr 10, 2019 | 01:25 PM
If it’s working it’s not the fuse. Replace the bulb. Sounds like an element is failing.
Old Apr 11, 2019 | 05:03 AM
ADAM1985's Avatar
ADAM1985
Default Turn signal light fuse
Plz i need to know whats the number of the fuse in the box , for right single light turn, 2010 grand caravan thanks
Old Apr 11, 2019 | 06:09 AM
You can find that info in the owners manual:
https://ownersmanuals2.com/get/dodge...s-manual-34805
Old Apr 11, 2019 | 11:35 AM
ADAM1985's Avatar
ADAM1985
There is no words say signal turn ?
Old Apr 12, 2019 | 11:58 AM
Then it may be another fuse, but as I stated, if the lights are turning on and sometimes hyper flashing, it’s not the fuse. But you can also check “tail, marker, running” light fuses as those are the same bulbs. Or there might not be a fuse if it’s powered by the TIPM.
