[3rd Gen : 96-00]: brake line ?
Old Apr 13, 2019 | 09:14 PM
Aaron Caudill's Avatar
Aaron Caudill
Default brake line ?
can anyone please tell me what this covering is over the steel brake line it is the rear line on a 98 dodge carvan coming off the wheel cylinder but i do not know what the covering is called or where to get a repalcement on thank in advance
Old Apr 14, 2019 | 10:03 AM
GumbyRT's Avatar
GumbyRT
It’s essentially a spring that’s wrapped around the lines at the factory to act as an insulator against vibration as well as protect the line from direct contact with the frame and body. The problem is corrosion starts building up between the coils and eventually contributes to line failure rather than preventing it.
It’s not necessary to replace it. When you install a new line, look for places where the line could potentially rub and use short lengths of rubber hose to protect it. Cut a piece of hose lengthwise to wrap it around the line and use zip ties to secure it.
Old Apr 14, 2019 | 03:21 PM
Aaron Caudill
Default Thank you GumbyRT
[QUOTE=GumbyRT;3435414]It’s essentially a spring that’s wrapped around the lines at the factory to act as an insulator against vibration as well as protect the line from direct contact with the frame and body. The problem is corrosion starts building up between the coils and eventually contributes to line failure rather than preventing it.
potentially rub and use short lengths of rubber hose to protect it. Cut a piece of hose lengthwise to wrap it around the line and use zip ties to secure it.[/QUOTE
