[General]: Chech engine lite
Old Apr 26, 2019 | 08:17 PM
moparornocar1972's Avatar
moparornocar1972
Default Chech engine lite
Check engine light on, runs rough, pulled code for misfire on #1, replaced coil pack, plugs , wires. Reset, check engine lite off, no code, ran good. For while, check engine light on again. 2007,2.4, 4 cylinder caravan. Only major work was head gasket, 100,000 actual miles on van.
Old Apr 27, 2019 | 04:03 AM
primem's Avatar
primem
did the misfire return on the same cylinder? if yes, do a compression check.
