[3rd Gen : 96-00]: Car won't start in morning but is then perfect until the next morning?
Old May 14, 2019 | 12:47 PM
HerrMyrgers's Avatar
HerrMyrgers
Default Car won't start in morning but is then perfect until the next morning?
Hi all,
My Dodge Caravan 1997 3.0L has been having troubles lately with starting in the morning. It first struggles to start but once it idles the car drops out as soon as the gas is applied or changing gear. After 3-4 attempts the car starts fine for the rest of the day. After consulting an auto repair shop that said that the battery we had was a bad battery and most likely causing the problem. After replacing the battery the problem still persists.
Any advice?
Thanks greatly
Old May 15, 2019 | 06:41 PM
GumbyRT's Avatar
GumbyRT
Are there any codes? Even if the check engine light isn’t on, codes can be stored.
Old May 15, 2019 | 07:52 PM
HerrMyrgers
Hey,
We get codes 12 &. 22. But then after about an hours driving they disappear again. Only to return the ne, t morning.
Old May 16, 2019 | 03:46 PM
IDon'tGiveARam's Avatar
IDon'tGiveARam
I searched for dodge codes, here is a page with a list from Dodge Trucks that is likely the same for us. Find your ECM and make sure the connections are tight, specifically the ground wire.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
