[4th Gen : 01-07]: 2006 Dodge Grand Caravan osc occupant restraint system
Old Jun 16, 2019 | 07:48 PM
Sai's Avatar
Sai
Default 2006 Dodge Grand Caravan osc occupant restraint system
I have a 2006 grand caravan with OSC system that looks into the the seat for weight etc. I have tried everything and now I’m told I need a new bladder system. This van isn’t worth the money they are charging to have it done. The light on the dash stays on and there’s no codes, when I go into the seat osc I see a code that says occupant clAssification undetermined. I read somewhere that some 2006 and 2007 vans were not equipped with Osc and if I change the main airbag module with one from a van without osc it will work as normal. Please advise if anyone had any luck fixing this issue. I am almost about to give up, tried everything.
Old Jun 16, 2019 | 09:13 PM
GumbyRT's Avatar
GumbyRT
Have you tried going to another shop for a second opinion?
Old Jun 16, 2019 | 09:24 PM
Sai's Avatar
Sai
I did try both are saying same thing
Old Jun 17, 2019 | 10:19 AM
GumbyRT's Avatar
GumbyRT
Please clarify - are you or are you not getting a code and how are you viewing it (scan tool or driver info center)?
