[4th Gen : 01-07]: Starting issue
Old Jun 19, 2019 | 02:52 PM
myrajean1's Avatar
myrajean1
Default Starting issue
2005 Dodge Caravan SXT, V6, 3.3L.
Van must be cranked 4 or 5 times before it will start. I can turn the ignition on without cranking 4 or 5 times just allowing the fuel pump to run. It will crank after 2 tries usually. Fuel pump, oxygen sensors and catalytic converter have been replaced. Worked great for a short period after the fuel pump was replaced and then began the hesitant starting again. No engine light or codes displayed. Runs great once it starts. Any suggestions. You can email me direct at brett.skinner63@gmail.com. Please put Van in the subject line.
