[5th Gen : 08+]: Washer fluid level sensor
Old Aug 8, 2019 | 02:51 PM
Bill Voisin's Avatar
Bill Voisin
Default Washer fluid level sensor
Hell all, I have a 2010 Dodge GC with a 4.0. the low washer fluid level signal comes on at start up when the fluid is full. Does anybody have any useful videos or links of where to find the sensor and how to remove it? Any help would be appreciated. Thanks in advance
Old Aug 8, 2019 | 03:07 PM
It is in the side of the reservoir. You'll probably have to remove the reservoir to remove it. Should be a couple of bolts holding the reservoir on. The sensor itself is held in by an o-ring. Just pry it out. Welcome to the forum.
Old Sep 12, 2019 | 11:34 PM
milanz's Avatar
milanz
I also have a 2010 4.0 SXT and had the same problem a few years ago. I accessed the sensor from underneath the vehicle lying on my back. It pretty much pulls out. I just cleaned the two blades/contacts using a wire bush and reinstalled and have not had a problem in 5 years. I always use a rainx washer fluid and I have heard that it coats the sensor with the water repellant substance so that it can't detect the presence of the washer fluid.
