[5th Gen : 08+]: Remote Starter not working
When attempting to start 2017 Caravan remotely receive the message "Remote Start Disabled - Start Vehicle To Reset" message but still will not work. Seems to only be working sometimes from inside the car.
Hi @clicketysplit,
We recommend visiting your servicing Dodge dealer for this. Please feel free to send our team a message if you are in need of support.
Darlene
Dodge Social Care Specialist
Darlene
r u doing this?....remote start...idle ten minutes....remote start...idle ten more minutes...remote start get message
the vehicle will only allow 2 remote starts in a row without a manual start. After that you must go out and start the car....and then it will reset. Its purpose is to prevent excess idling.
this is detailed in the owner manual.
if that is not the problem...you have a fault that needs to be fixed. check for codes and post them here. any dtc will disable the remote start.
No. I have tried from cold, I have tried after manually starting, but it only seems to remote start from inside the car, and yes, I have been having electrical issues with the vehicle (see other thread) which have been intermittently keeping the traction light on after startup. Thank you.
