[4th Gen : 01-07]: Transmission problems
Old Oct 16, 2019 | 04:13 AM
JWPautocare's Avatar
JWPautocare
Angry Transmission problems
I have a fleet of Grand Caravans and in one of the I have replaced the transmission with one I had on my floor. Now after putting it in I now don't have reverse and when I put it in neutral it acts like its in drive and I have no low gear. I have replace every sensor and the solenoid and still same thing I have also re learned the tcm and still same thing. Any Ideas?
Old Oct 16, 2019 | 01:29 PM
GumbyRT's Avatar
GumbyRT
Are you sure it’s the right transmission for the year? If you installed a trans with a different year there might be programming that needs to happen or it may not be compatible at all.
Have you tried pulling any codes?
Old Oct 16, 2019 | 03:21 PM
IDon'tGiveARam's Avatar
IDon'tGiveARam
Sounds like the shifter is out of adjustment. I haven't worked on a tranny since a 1991 so I don't know how they are now but back in the day you could adjust the cable or linkages to make the shift lever indication of N line up with the transmission arm being in Neutral and so forth.
https://www.chryslerminivan.net/thre...ustment.14217/
