[5th Gen : 08+]: Transmission leak 2013 dodge grand caravan
Old Dec 19, 2019 | 12:40 PM
Ryan Kane's Avatar
Ryan Kane
Default Transmission leak 2013 dodge grand caravan
My transmission fluid is leakinng from 2 rubber plugs under car right under brace? What would be the cause if this and what r those rubber plugs? Its a lot of fluid.
Old Dec 19, 2019 | 07:47 PM
GumbyRT's Avatar
GumbyRT
Can you post a picture? What is the year, model and engine of your van?
Old Dec 20, 2019 | 12:19 PM
Mopar340's Avatar
Mopar340
I think what you're referring to are the transmission speed sensors the 62TE has 3 speed sensors one near the top which is the input speed sensor and 2 on the rear of transmission near the bottom one is the transfer speed sensor the other is the output speed sensor. The O rings could be bad on one or both sensor allowing fluid leakage. These sensors would have electrical connections.to each one.
