[5th Gen : 08+]: 2012 Dodge Grand Caravan front windows and locks issue.
Old Jan 18, 2020 | 11:04 PM
L'roy1983's Avatar
L'roy1983
Default 2012 Dodge Grand Caravan front windows and locks issue.
I have a 2012 Dodge Grand Caravan and am having issue with the front widows and the power locks. I can lock the doors with the key fob, But it will no work on the door control. The two front window do not work as well and the back windows work fine. Has anyone had this problem? Thanks in Advance
Old Jan 23, 2020 | 12:10 PM
DodgeCares's Avatar
DodgeCares
Hi L'roy1983, I do apologize for the trouble you are experiencing with your door locks. We understand you are reaching out to fellow forum members, however if you are not able to remedy this concern with the advice provided here, I kindly recommend connecting with your local Dodge dealer.
Rob
DodgeCares
Old Jan 23, 2020 | 01:21 PM
Mopar340's Avatar
Mopar340
I had a similar problem not with the power windows but the powerdoor locks however I tried the passenger side control and it worked so I determined it was the master door control on the driver side that was the culprit change it out and everything worked fine. The problem is the push pad underneath the buttons doesn't make contact anymore. I bought mine online at Mopar Parts Giant,
