[5th Gen : 08+]: Door Open Sensor
Good afternoon everyone, Quick question hopefully someone can help out with. Got a 2014 Caravan that I am ready to drive off a clif, nothing but hassle right now. So the currenty issue is when we open the driver door the van doesn't sense it is open. The Radio stays on, the doors in the rest of the car do not unlock, no door is ajar alarm goes off and the head lights can be on and it won't notify you.
if I open the passenger door the radio shuts off as it should.
I assume this is some sort of sensor in the driver door that has no failed can anyone shed some light on what I am looking for? I don't see the old pin style sensor anywhere so must be somthing else.
Thanks
David
Thanks
David
Thanks
David
Thanks
David
Rob
DodgeCares
Thanks
David
Thanks
David
The quickest test is to access the latch connector and jumper pin 3 (violet/signal) to pin 4 (black/ground). If the other doors unlock and the cluster illuminates, you can try cleaning the latch with brake/parts cleaner and compressed air. If that doesn’t work, it’ll have to be replaced.
If jumping the wires doesn’t work, you’ll have to troubleshoot the circuit between the latch and TIPM to see if it’s the wiring or TIPM that’s at fault.
