[3rd Gen : 96-00]: 2002 Dodge caravan cranks not start
Old Feb 18, 2020 | 02:25 AM
diligentinquirer's Avatar
diligentinquirer
Default 2002 Dodge caravan cranks not start
2002 Dodge caravan cranks not start. first happened when brake pads were bad (just worn out. Now when I am replacing with new brake pads it again cranks but will not start. 3.3; 6 cylinders.
Old Feb 20, 2020 | 10:02 AM
Ryan Greene's Avatar
Ryan Greene
A crank but no start can be a lot of different things. Start with the most obvious first. Is there gas in the tank? Is your air filter clogged? Can you hear the engine turning over, or is it just clicking? Clicking can be a dead battery. Can you check if there are any codes? Then you'd probably go to spark plugs, coils, fuel injectors and fuel pump, if those other things don't help you!
Good luck
Old Oct 25, 2020 | 04:21 AM
easyeric71's Avatar
easyeric71
Default Dead van
Thanks for th reply. Not doing any of that. Won’t crank. Fresh battery. Scan tool not communicating with computer. Thinking broken/fried wires.
